rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Sun Oct 31, 2004 6:59 pm
The SARD Racing FPR I have can go as high as you are looking for in pressure... the fuel pump you have can not though... do a search on google for 3si fuel pump and you should find some VR4 guy who tested a lot of pumps and shows what they can do at different pressures.
As far as your idea goes... I calculated at work (I work for Bosch Fuel Injection Development) that the 20's 270 injectors are about 290's or 300's at 3.5 bar... yet, still my advise would be to get the right size injectors. Even with the RX7 injectors you sacrifice targeting since the injector is slightly shorter. By the time you made a system that could reliably support 100 psi (lines, pump, fittings, regulator etc)... you could have bought 6 correctly sized injectors.
Take this with a grain of salt, but I'd imagine the issue in running such high pressures would be sticking the needle open... not a great problem to have...
Hope this helps...
