2x brake wear on one side and blinking cruise control light
mattropolis
Hi all,
I have a 93 Altima with 185k on it. I do the brakes myself, and the passanger side brakes seem to be wearing about 2x as fast as the drivers side. Everything is working, but when the psgr side brakes are at about 10%, the other side is still about 50%. Also, my rear brakes are not engaging very well either. The pads are hardly worn, but I've gone through 3-4 sets of fronts.
Also, since doing the brakes, I notice that if the cruise control is on, but not engaged - when I press the brake pedal, the cruise light on the dash might blink for a second. Someone mentioned how to fix that before, but I forgot what to do. Something about resetting the cruise sensor or something.
Thanks in advance!
MaximA32
Sounds like a bad metering valve for the brake system. Have you checked the system for air pockets?
