1. Are the mounts on the frames there so if I have a 2WD hardbody truck and I can get the front suspension from a 4WD I can bolt it in? My concern is only the suspension. I will not need to mount the diff or the transfer case just the control arms to hang the 4WD hubs.
2. Which side is the front diff and drive shaft on, the driver or passenger side?
3. Is there a disk brake conversion available for the rear?
