Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Fri May 02, 2008 12:27 pm
The 2wd sump holes are already there on a AWD block, so an adapter is not needed. I think you need to mod the pan itself though just to keep oil inside after you remove the axles.
I'm not goind that direction though. I want to make a 2wd block work in a 4wd car. Yes the transmission bolts up, I know, it the block bolting to the front sump with the axles and junk. Coolwhip is tracking with me.
Here's a thread on AU that I'm asking in. Might give some of you a better idea what I'm talking about. -------> http://www.skylinesaustralia.c....html
