Desert Rat »
https://forums.nicoclub.com/desert-rat-u54558.html
Mon May 23, 2011 9:35 am
To swap in a 4x4 housing you'll at least need to cut and reweld perches because 4x4s are spring over axle. 4x4 axles will also have considerably lower gears which may not be a good match if you're running stockish height tires. 4x4 axles will be a C200 from a 4 banger truck 86.5-95 or the larger H233B from a V6 truck or 96-97 4 banger. LSDs are fairly common in the H233B axle, especially pathfinders. Pathfinders have a 5 link rear suspeion, but the 3rd members can interchange.
You'll learn a lot reading the axle sticky at the top of this forum.
