I checked into my similar problem today and fixed it, i'm also using a z31 turbo btw. first off i closed the spark plug gap to .025 on a fresh set of NGKs (bkr7e), and also cleaned up the dist. cap since it had become slightly corroded from sitting in my driveway since october when she came off the road. The coil wire was making a pretty poor connection as well....anyways, no more miss/backfire under load!
You only experience it when the car warms up, right? Check into the ign. module and the O2...you did put in a fresh one with the turbo didn't you? There is a possibility if you re-used the old one that it got damaged in the swap and is now reading incorrectly, they are VERY fragile! They can take tons of heat, but one drop and it's all over.
