2piece underplenum pipe
willmoodom
Car: 1991 Q45
Does any one have a picture of how this pipe sits and or is installes under the plenum? What lines connect to it?
OwnerCS
The under plenum water hose or the vacuum pipe to nowhere?
I've got a bunch of under plenum pics that I can put up..
willmoodom
Car: 1991 Q45
The vacation pipe is what I need. Thanks
OwnerCS
Here's a slide show about under plenum hoses and related hardware.
http://s286.photobucket.com/albums/ll11 ... =slideshow
willmoodom
Car: 1991 Q45
OwnerCS wrote:Here's a slide show about under plenum hoses and related hardware.
looked through the photos and the pipe i m speaking about is not shown. reason i cant remember how its installed is because the previous owner butchered the pipe doing a back yard fix. it was cut into 3 pieces! anyway, the pipe is actually made up of 2 pieces welded together. they are fairly thick in diameter. vac,no fluid. one connect to the
"Y" shape hose at the back of the intake.
OwnerCS
Updated the slides with UP_015 through UP_020 to show hoses and pipes that are part of what I call the "plenum assembly."
I think I remember it being easier to connect the Y hose to the "vacuum tube to nowhere" if the IACV is disconnected from the plenum but still connected to the Y. If the IACV is disconnected, it lets the Y hose flex better to make that final connection.
Once the Y hose is connected and clamped to the "vacuum tube to nowhere" the IACV (with gasket) can be connected to the back of the plenum. Be careful not to damage the IACV gasket during reassembly.
I used a silicone based lubricant (grease) -- Super Lube (Ace Hardware) or Sil-Glyde (NAPA) to lubricate the hoses so the connections could slide together with minumal effort.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
KY works great also.
flyingbrick
I recommend KY Warming Gel.
