gingerbredman »
https://forums.nicoclub.com/gingerbredman-u67700.html
Mon Feb 22, 2010 4:50 pm
Yeah, you can hook up a +cable running from your battery from the trunk up to the factory +connection up front. As for ground, you will have to run a cable all the way from the battery up front to the engine bay. Just hook that new ground up to the intake manifold where the factory ground is located.
I have mine this way, I skipped on running a ground from the battery to the front and had problems. My connections on my alternator got extremely hot, and even burned off a couple of times. Since then I've run a ground from the battery to the front and replaced my alternator wires and haven't had an issue.
I figured the ground would travel the entire length of the car regardless of location, but apparently it's not that simple heh..
btw the cheapest way to do it is to just go to autozone and get a set of the 16ft jumper cables, they're perfect
