I already had a spare set of lights from when I did my car, so once he gave me the go ahead, i took them apart and started the painting process.
His car is black, so he wanted a gloss black theme going
After I drilled out the back of the housing, i had to start doing some test fitting and firing of the lights to make sure everything works before I get too deep into it.
After i got all the parts painted (3 coats of primer, 4 coats of Gloss Black paint, and 4 coats of Clear coat) i did a test fit just to get an idea of how things will look together
Time to start fabbing up some Brackets. I used 2" L brackets from the local hardware store. I had to cut one part of the L down by 1" to make things fit the way I needed. Then I had to extend the holes that were pre-drilled so that I can adjust the hight accordingly so i can get everything nice and even.
The brackets are hidden from sight, so wasn't too concerned about how good they looked, just as long as they work.
The Ocular shrouds are too wide to fit in the housing, so i had to shave them down with my sander to get as good of a match as I could. Unfortunately, One was shaved down too much, so once the new shroud shows up, I can finish the job.
This is just a test fit
You can see the gap on the side
as you can see, one side has little to no gap, and the other ....Well sucks
Today cleaned and resealed the light that was good. Made sure the aim was good with a nice flat cutoff.
