2nd gen Rogue front bumper removal
skylightpigeon
Car: 2015 Nissan X-Trail T32
Hi,
Is there a link or instructional video on how to remove the front bumper for the 2nd gen rogue? any help would be greatly appreciated. thanks!
greetings from the Philippines
darylzero
check out the Field Service Manual http://www.nicoclub.com/FSM/Rogue/
skylightpigeon
will do, thanks!
Monty90
Car: Xtrail 2016
Remove all fastener from below the bumper, remove the front fasteners of the inner fender, once you remove the fastener pull the fender flare and remove one screw per side at the corner of the headlights, there are two hard to get fasteners inside the front grill that you must align by twist them with a flat screwdriver
skylightpigeon
Monty90 wrote:Remove all fastener from below the bumper, remove the front fasteners of the inner fender, once you remove the fastener pull the fender flare and remove one screw per side at the corner of the headlights, there are two hard to get fasteners inside the front grill that you must align by twist them with a flat screwdriver
thank you Monty90. did you use a panel removal tool for the fender flares or did you just pull it by hand towards you?
Monty90
Car: Xtrail 2016
Sorry for the late response, I did it Just with the hands
skylightpigeon
thanks for the tips guys!
skylightpigeon
do you guys know if this connector is for the fog lights? my unit did not came stock with fog lights. it can be seen on both sides, passenger and driver.
frijolito
Car: Rogue (Xtrail) 2020 Advance
Looks like the right type yeah..
Did you rewire the horns or use existing wiring by the way?
skylightpigeon
i used a relay that came with the hellas for the horns and used the front grill horn connector for the switch to the relay.
rajesh1136
skylightpigeon wrote:
Thu Mar 31, 2016 8:19 pm
How did you remove the front grille. I read the manual that to remove bumper you need to remove the grille. Not able to remove the two bottom clips
Return to “Rogue Forum”
