ampsucker »
https://forums.nicoclub.com/ampsucker-u63262.html
Sat Apr 28, 2007 6:30 pm
i think there are two different concepts at work here.
first, i think of riding the clutch as anytime your foot is on the clutch when you aren't actually pushing it in or letting it out during shifting. when you get in the habit of riding the clutch (letting your foot stay on the pedal in between shifts or worse, just when driving around) you take some of the pressure off the pressure plate which allows the clutch pad to slip a bit. very bad if you want your clutch disk to last a long time. also bad on the throw out bearing which has to rotate whenever you have your foot on the pedal.
when first staring off in first gear, you're right about letting it out half way, or feathering it, to get started. again, here it shouldn't be necessary to rev the engine much. you're still in the break-in period. save the hot rodding for after ;-)
when shifting between higher gears, i don't recall ever feeling the need to let the clutch out half way. it should be a single, positive, fluid motion. so, for example, from 2nd gear, wind up the engine rpm a bit, push in the clutch, let off the gas while shifting to 3rd, then let out the clutch while timing the engine rpm drop to match the new gear. at the same time, give it a little gas to get going in third.
i know it sounds complicated to read, but it really should be a natural, fluid, motion. it's the timing that you have to get used to. you should be able to let the clutch out quickly and smoothly after all gears except first and there shouldn't be any noticeable shock to the drivetrain, tires squeeling or anything like that. just nice, smooth, acceleration. let the engine pull through the gear, nice smooth shift to next gear, pull through gear, etc.
just takes some practice. first, perfect smooth shifting and rpm matching during break-in period. then work on more advanced stuff later on once you get a good feel for the car. you'll get the hang of it. ;-)
btw, wish i was you. sounds like fun....
i learned to drive stick on an old van. it was "three on the tree". you shifted through the gears on the steering column instead of down on the console between the seats. i stalled it out quite a few times until i got the hang of it. i also vividly remember test driving my first 5-speed with my dad. it was a 77 280z. i was getting into a corner and wanted to shift down from fifth to fourth, but grabbed second instead on accident. i let off the clutch a bit to fast and the rear tires chirped and i'm pretty sure my dad pinched a hole in the passenger seat.
anyway, just take it easy and have fun learning. you might try riding with someone with good technique and watch how they manage the timing of everything.
