2k gxe cranks but wont start
General discussion area for the L30-chassis Altima
Bruce72765
Car: 2000 Altima GXE
I have a 2000 GXE that had a cracked radiator. I sealed it and it ran fine. After a couple months though it blew while on my way to work and sprayed radiator fluid all over the engine. It didn't overheat..the pressure just blew the crack that was sealed. Since I was halfway between work and home I filled it with radiator fluid and it started right up and drove for another mile or two before spraying fluid everywhere and dying. Towed to shop and it ran but very very rough. Mechanic said there was "something bad wrong down deep in the engine". My buddy and I have tried to get it running. It cranks but wont start, I've changed the crank sensor and distributor but still nothing. I'm almost positive there is no blown head gasket. Any thoughts or ideas would be greatly appreciated. Sorry for being so wordy.
lobo_s10
Car: 1998 Altima GXE 5spd, cold air intake, strut tower brace, fireball 2 muffler, vortex generators on roof
Check the timing, is the rotor turning on the distributer, check spark at the plugs pull them out hook to wire set on a round conection see if they spark, turn the engine a couple times blow water iut cylinders if any in there. Just a couple to check
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
Have you done a leakdown or compression test to actually verify that you don't have a bad head gasket? Any error codes?
Return to “2nd Generation Altima Sedan (1998-2001)”
