Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Sun Oct 31, 2004 7:52 am
If you think about it, it's not realy that bad, if the transmission lines up with the shifter hole, no problem. Customizing and relocating engine mounts isn't all that bad, Same goes for the transmission mounts. What I wouldn't like is probably the exhuast system. It's on the passenger side and there's no grooves in the body to fit a nice 3 inch exhuast. That's my only main concern. Everything else, isn't that bad. If you do it yourself, it's not gonna cost you much, just have to run to the junkyard or custom bend and weld your own engine mounts on the chasis. If you have someone else do it, say, a shop, have fun because you'll definately exceed your budget of $1,000. Regardless, have fun and good luck.
