2jz 240sx swap questions
Black_label_240sx
Car: 240sx s13 with rb20det swap
ok, so rb20 died :squint: oil pump failure.
throwing around the idea of doing a rb26 or 2jz swap as Sr-ka's arn't my thing.
I know for the 26 you need to use a rb25 transmission and that wiring can be tricky.
Well what else is there
for the 2jz.
I can't seem to find anywhere that will give me a definitive answer and what jz motor came out of what.
I can get a good deal an a 2jz gte vvi, but I'm trying to find a 2jz out of a usdm supra. did those come with vvi?
Also can't seem to find which are front sumps verse rear sump on any of the jz engine.
so if anyone knows of a good website that has more clear cut specs are each jz engine, please let me know.
Anything else that you think I should know about the swaps let me know
thanks
