288 RWHP @ 10psi
Frozen240
Car: 92 240SX KADET
Finally made it to a dyno to see what kind of numbers the car is putting down. I'm using a JWT ecu with a z32 maf and 72 lb inectors. The engine is built with Arias 8.8:1 comp pistons, stock rods, and ARP hardware. I'm using a garrett TO4B with a .60 comp.
I was suprised to see how lean the engine is running. Everyone has always told me that the JWT will run super rich and have very conserative timing, not so in my case. I think that I'm borderline safe with the AFR's and the timing cannot be advanced anymore than the stock setting of 20*. We tried to advance the timing a little, but it would start to ping, same with an increase in boost. I'm leaving it at the 10 psi level for now. I guess that is the worst part about the JWT programming, you can't adjust anything and have to live with it the way it is. I would like to make more power out of the car, since it's built for it. http://nissaninfiniticlub.net/...t=500
klattr1
Car: GT42R powered S14/KA
powerwise thats pretty good.
of course you would make more power if you had the compression of what most of the 350 rwhp at 15 psi guys make (9.5:1 vs your 8.7:1)
JWT ecu's tend to run 14-15 deg. timing in WOT at 13-15 psi. some call that conservative, but for 93 octane, thats pretty good (not overly conservative and still will make some power and be safe).
now, throw some race gas in there (110 or 116), and ramp the base timing up another 3-4 deg. correctly and of course you'll make some more power.
Structure240sx
do you have a fuel pressure gauge?
jwt has been know to send out some bad tunes. im putting in the same ecu tomorrow, hope it works out better for me
Frozen240
Car: 92 240SX KADET
I was only running 91 octane, as that is the best I can get at the pump.
I don't have a fuel pressure gauge in the car, but I have checked it with a handheld gauge, it is close to the stock setting, but I know the gauge isn't 100% accurate. Still using the factory regulator as well...
Hmmm, maybe I'll just run race gas all the time.
I have to say thanks to all you guys on the forum, I really could not have done it without you!
Structure240sx
91 may be causing a problem then
good job though so far
were you auto before? are you still now?
wait until you start pushing some real boost through, i have the same turbo kit if you didnt remember
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Looks to me like a dead/dying fuel pump...or not enough voltage - Is yours hardwired on a seperate relay?
??? - Brian
WDRacing
You should be able to run 15psi very easy with that setup. Knock should not even be a factor until you start to max out your injectors or fuel pump. So we know your injectors can make WAY more power, that leaves the fuel pressure. Or, you may be running a bad ECU tune that has to much advance. But I'd start with the fuel first, the beg borrow or steal a scanner and check out your WOT timing.
Frozen240
Car: 92 240SX KADET
The stcok pump has been replaced with a Walbro 255l/hr unit, sill using the factory wiring. I'm also using two step colder plugs gapped to .030".
Structure- I've got a 5speed, always have, always will!
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Speaking of lean mixture's....
I have the jwt ecu, 740cc inj and the Z32 maf and these are my a/f ratio's (wideband)
8 psi = 12.512 psi = 11.515 psi = 10.4
Thats the highest ive gone so far... According to jwt, base timming needs to stay at 20 degree's and u need to run 91 octane or better. And also retain STOCK fuel press regulator. OF course u can run race gas and advance the timming 2-3 degree's as noted earlier..
nissanfanatic
Car: 1992 Nissan 240sx SE
DAmn nice numbers man. REmember what trim compressor wheel you are running?
very close to my setup as well cept I'm running the enthalpy tune.
Structure240sx
nissan- he started out with an nsport kit just like me, so he has the same turbo as me, jealous huh
nissanfanatic
Everyone has the good T04B. :P
Frozen240
Car: 92 240SX KADET
If the fuel pump is a problem, how much would the pressure drop off under WOT? Or what would an acceptable range be?
Would 5 psi be too much?
I plumbed in a mechanical gauge into my fuel line and I'm going to check it out today. I don't know how accurate it is, but it will give me a good indication of what it happening.
:: orion ::
ANY fuel pressure drop is BAD.
The stock S14 pump can hold the correct pressure under ~12-13psi of boost...your Walbro should not drop AT ALL.
It's cheap insurance to hardwire it...see here:
http://www.ka-t.org/tech/
- Brian
