480sx »
https://forums.nicoclub.com/480sx-u50548.html
Sat Feb 21, 2009 4:19 pm
Its just a dyno sheet and a number. You say it yourself, the car is fast as hell and feels like it pulls past 5500 rpms and doesnt drop off. So who cares what a dyno sheet says, they are meaningless IMO for anything other than tuning. 1/4th times and track times are all that really matters, oh, and the looks on the drivers face of the z06 you just pulled on.
Id be willing to bet that the cams respond better with more boost. I would say your power wouldnt drop off nearly as bad. In addition, the t2 flange could be choking you at higher rpms causing that 1-2 psi drop, although thats kinda a stretch. Also, your running pretty rich, average 10.7's in boost. Thats also going to cause you to lose some power. Do those readings agree with your AFR gauge on the car?
Also, running strait wastegate is not really the best way to get a steady boost setting. They will fluctuate some without a EBC.
Pressure test your IC system and see what you find.
