evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Dec 05, 2006 5:53 pm
if you've got an intercooler any combo should be ok, you might need to bumop the base fuel pressure a bit for the added compression, if you plan to keep low boost levels, i'd go for the 8.5:1 build or as close to it as possible, the higher compression will give you more off boost power and faster spool
the T4 has too large of a turbine, it would take too long to spool, the T3 is well stock, the T3O4E .63 A/TR with a 57trim wheel is what I am running, it's good to about 400whp max and spools quicker than the old stocker I replaced, I am considering playing with some different options as mine comes on rather violently, it's fun but not ideal for autocrossing which is my primary purpose for the car
