280zx turbo. fuel pump
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
blondela
Car: 280zx turbo 1983
Hi i have a 1983 280zx turbo . the fuel pump has stopped working but when its removed and given an independent power sorce its fine. does anyone know what the problem is?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
could be the AFM, if it's stuck open or bad it won't alolow the fuel pump to come on, also the fuel pump relay turns the power on adn off, and the fuel pump modulator located above the ECU modulates the voltage to the pump
Bleach
Car: Three Z-cars
Have you checked fuses and fusable links?
The fuel pump relay is in a block of 3 relays in the far right side of the dash. Remove the glovebox to get at them.
Check connections under the rear deck carpet for the fuel pump as well if all the fuses look good. and, if there is one specific for the fuel pump, replace it even if the fuse appears good. (or swap it with another fuse)
Return to “Datsun Z Forum”
