280zx
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
deanbrush
Car: 82 datsun 280zx turbo
hey im pretty new to "nico" i own an 82 datsun 280zx turbo and im having an issue, i blew my upper radiaitor hose ive since replaced it but now when i ndrive the car it wont go over 2k rpm if i get rolling in the car and put it in neutral it dose the same thing i cant get past 2-3k...it sounds like it wants to but either fuel or air or ignition is giving out... but if the car is in park i can hold the rev limmiter all day at 6+k , i know the vq30&35's like the back of my hand but this l28 is kicking my a**. any info would help
thanks in advance, dean
and to add the car dose not die it sits in limbo until the rpm's drop then it tries again....and again..........and again, i need to see a doctor now for my neck lol
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
could be a few things, first the afm, check the connector at the afm, and when I say check it I mean unplug it make sure there is no moisture inside either side of the connector (remember that hose you blew?)
CHTS, or CTS, it's located int he lower thermostat housing, it's ont he passanger side of the head, the connector looks like an injector clip, make sure it's connected securely, if it's disconnected the car runs stupid rich to the point that it floods itself
ignition, check the distributro cap for moisture (again open it up, that blown hose was right next to the distributor) also check the plug and coil wire boots, any mositure inside there can cause loss of spark
fuel pressure, sometimes the fuel pump dies slowly, it will provide enough pressure for idle but when you rev and the vac drops the fuel pressure raises and the pump shuts off, this is an easy test, just place an inline pressure gauge between your fuel folter and the fuel rail (bonus points if oyu add enough hose to place the gauge under a wiper arm so you can keep an eye on pressure when you drive) should be around 42 psi at idle and climp as rpm increases while driving
deanbrush
well after a few hours of checking whats already been checked several times it was none of it..i disconected the vehicle speed sensor...line thingy right before the speedometer on the inseide of the car and uno presto! problem solved. or atleast one problem down. i cant wrap me head arround it the car works fine now but i dont know how fast im going(like i care) ecu problem? prndl problem? fuel cutoff switch/relay? im just happy i can drive the car
evildky
06 Nissan 350Z GT
there is no speed sensor on the s130
deanbrush
lol i understand that but idk what to call it. its connected at the end of the trans near the out put shaft and it runs up the frame and into the firewall and directly to the speedometer.. its a square tube in a round pipe..i disconnected that
evildky
06 Nissan 350Z GT
The speedo cable? There is nothing about the speedo that effects the way the car runs, perhaps it was a moisture issue that dried up and resolved itself
deanbrush
it cant be..because the whole day i had been working on the car an drying things out nothing helped. i took the car up the driveway and then back down disconnected the speedo cable went back up the driveway and there was no issue......some mysterious wet connector somehow dried up in 45 seconds? im going to reconnect the cable tomorrow and see if the problem comes back, but that would be the craziest coincidence if i diconnected the speedo cable for no reason and the problem solved its self..
evildky
06 Nissan 350Z GT
when you disconnected it did the speedomter stop working? the speedo cable drives the speedo, cmes form the tailhousing of the trans, comes up and through the firewall and intot he back of the gauge cluster directlu beind the speedometer
deanbrush
ya..no idea how fast im going but the car works.. still havnt reconnected that cable i had a long day today but i want to see if the car still runs right when its reconnected, hopefully ill have some info tomorrow, but just wondering if i do reconnect the cable and the car goes ape s*** again what could that possibly mean? as far as i know the ecu was only needed for translating the info from the afm and tps so it has proper air/fuel besides the injectors and a few small meters, like you said the speedo is mechanical and not electronic sooooo.
evildky
06 Nissan 350Z GT
if you reconnect the cable and the car starts acting wierd then you have some sort of ground or short, there is nothing electric abotu the speedo cable and if it's trying to groudn through the cable or short then there is another groudn or short issue you must find
300ZXttZMAN
Also just as a thing for you to do in the future..
Please use a better title...
Return to “Datsun Z Forum”
