centralcoaster33 »
https://forums.nicoclub.com/centralcoaster33-u27573.html
Fri May 12, 2017 5:09 pm
The bolts to the diff can be frustrating. Keep up with the penetrating oil soakings regularly. Consider using a wire wheel to brush off any excess rust (to avoid rounding the nut off). Be sure to use a hex socket, not a 12 point (to avoid rounding the nut off). Put the transmission in gear and the e-brake on tight to keep it from spinning. Use a breaker bar with the hex socket and torque on it to pull out all the slack in the driveshaft (I mean, it always seems to turn a few degrees even in gear and with the e-brake on) when you can't move it anymore, use a hammer to hit the breaker bar with a sharp blow. I hope that explanation makes sense. Anyway, this should help in breaking them free without rounding them off. Another way to hold the shaft from spinning is to put another wrench and socket on another nut and you pull that one on tighter while using the breaker bar to loosen the one your working at.
Don't give up because one won't come off. Work on one at a time and be sure to move on to the other three even if you don't break free the first one. Each time you'll get a little closer to having them all off.
Sometimes, rare of course, you can try and tighten the nuts or bolts to break them, then go back to loosen them once they turn a hair or two. Worst case? Cut em all off and replace them. I don't recommend that until you've rounded them all off accidentally.
PS - Be careful with a torch. You are near your gas tank.
PPS - Welcome to NICO Club!
