no rust on my z i just cant find parts for it i been looking all day and found a few places but no one has what i wantchitownguy wrote:I've seen a 280z drift before. But since they dont have powersteering it gets pretty hard. Also Z's have Macpherson struts all around. Coilovers arent bolt-on and the cars are old so rust is bound to be found somewhere on the car.
its like a housing that surrounds the carburetor and allows air to force is way into the carb..chitownguy wrote:For suspension you could get the ground control sleeve overs and use Koni's or you could get the ArizonaZcar coilovers which is what I'm getting. Motorsport Auto has lots of stuff that you need too. And I dont know what your talking about for the carburetor.
name ur price and show me the picsDJButton wrote:Well my 280 is decent enough I suppose, but I certainly wouldn't actually drift it, I've gotten a little sideways in the parking lot leaving work, but honestly there's so many things I'd replace before doing any serious driving. Sway bar's/strut bars/full cage would be first in order of body roll, and coilovers, upgrading stock brakes along with an LSD would be enough, I suppose to track it. If you're already rockin the L28ET then you should have enough HP to drift as well. I have a good condition '79 280ZX 5sp, Save yourself some time and money and buy it from me! Already FI and 5Speed. lol
evildky wrote:ok, it's a header as in singluar as it's an inline 6, not headers plural as in a V6, and it's not a header it's an exhaust manifold, the stock turbo exhaust manifold can be found on ebay form $50-$100, and if you've got carbs on a 280ZX then someone swapped them in! and if you want to torbo the L6 then unless you are a gifted fabricator and a carb wizard or stumble upon an old turbo tom set up, you're gonna want injection, the easiest and cheapest was is to use a complete 82-83 280ZX Turbo Donor
the 280Zx uses the R200, same as you're 240sx, only it's the longsnout version, any LSD carrier you can fit in you're 240sx will fit inside the 280ZX housing with the 280's gearset, that second vid looks like an open diff to me
an on the drifting thing, you don't want a car to handle if you want to drift, you want it to stay flat, drifting is to excede the maximum slip angle, we do this by taking compliance away so as to narrow the allowable slip angle, stiff suspension, tires with large tread blocks
adn the 280zx does not use macphearson on the rear it uses a shock and a seperate spring taht rides on the semitrailing arm, I believe with a threaded shock body a standard 2.5 coil spring would clean in the rear, if not I know I've seen a seat adapter to secure and allow for use of the smaller ID standard springs
it's been done, nothing new there,back to your car, you said webbers? DGV's or DCOE's? how good with carbs are you, there are plenty of N/A L6's putting down 250 whp with the DCOE's, I don't think DGV's are up to task, how about you start telling us about your car, for instance, what engine and cylinder head do you have? the block casting in cast just forward and below the drivers side engien mount, the head casting is cast between #1 and $2 spak plugs at the base of the headnismo 03 wrote:
ok so best bet is to get another 280zx and take my weber system off and replace it with a regular intake manifold. upgrade suspension, breaks and add a roll cage.
what if i just droped a 350 small block with a blower????
Yea I forgot he was talking about the 280zx and not the 280z.evildky wrote:adn the 280zx does not use macphearson on the rear it uses a shock and a seperate spring taht rides on the semitrailing arm
ok so you did the turbo swap on the L28E, with stock L28E electronic's? something went wrong so you swapped carbs so it's now just an L28, whay carbs? are there 2 or 3? are they downdraft? or sidedraft? is there a thumbscrew in the top of the carbs? when you re-assembled the block did you line up the dots on the oil pump with the dot on the oil pump/distributor driveshaft? was the cam and timing chain set correctly with the crank? and at TDC compression when the oil pump and shaft were slid back into place? and when you put the plug wires back in you remembered taht the distributor spins counterclockwise so the plug wires are connected in firing order counterclockwise? just trying to hit all the typical problems people have with these, they are pretty easy to deal with if you know what to look fornismo 03 wrote:o have no idea what that is
all i can tell u is that it is a 280zx non turbo l28e
the turbo was added by my self and a friend. computer took a **** on it self and died after playing around with it for a few i took it to a few mechanics that acted like dirt bags and try to tax me a lot of money just to look at the car. Finally in a desperate move i went with the carb. and got it running again. the engine had a huge leak coming from the back towards the transmission. so it was taken apart and rebuilt. after that i dont know but i think we put the distributor in wrong and have had a b!$t% of a time trying to get it to go.
Now their telling me to get it running or get it out of the garage ant truth be told i wan to keep it
