If you like pop up headlights maybe you should consider a Z31? Very comfortable cruiser, adequate power for the n/a and loads of potential from the turbo, the same crappy IRS as the S130, slightly better brakes, slightly more difficult to service but probably a little more dependable mostly due to the age of the parts, and more of them are still available. Also easier to find a car as it was the best selling Z car of any generation.
The stereo is weak on the NA miata and you can't really hear it with the top down unless you got an optioned car with the headrest speakers which are tiny and blow out then you can hear the crackle with the top down
Power windows on the NA are terrible, and the wipers are marginal. The NB had and a better stereo, power windows that actually work, and better wipers. also the torsen equipped NB's are far superior to the VLSD optioned NA's, also NB's got a glass rear window in the top and an improved top design. The NB's also had a more spacious usable trunk, bigger wheels and more power.
When I say modded I didn't mean the engine, the 1.6 or 1.8 miatas are fantastic little motors and what they lack in power and torque they make up for in high rpm goodness. Not much you can do to one of them to hurt them short of ripping the oil pan off on a speed bump. When I see a car stanced I wonder what they did to get down there and to get that much camber, it doesn't just happen, so there is a fair chance someone cut some springs, slotted, cut or bent something to get down there, also a stanced cat has the potential for loads of damage to the under bits, including the tub, the subframes, oil pan, diff housing etc. If you are considering a car that's modded heavily find someone who knows these cars and these mods to look and see if it was done properly or if any damage has occurred as a result. Keeping in mind that stance means increased tire wear, increased steering effort,shortened life span on tie rod ends, ball joints, suspension bushings and wheel bearings, decreased handling, braking and acceleration.
