280zx calipers on my 510
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
mipo510
Car: 1970 datsun 510
well im doin the 1983zx strut swap in my 510...i think i found my rotors but i dont know what calipers to bolt on??...
i can get the stock 280zx calipers to put in....
or does n e one know of performancr rotors to bolt right in???
help!!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
um... if you pput the S130 cstrut on why not take the entire assy rotor and caliper included? as far as upgrading form there, brembo makes slotted and crossdrilled replacement rotors, or you could get the arizona z car big brembo upgrade but it ain't cheap!
mipo510
koool...sweet.....would u know of any on-line places where i can look them up...or who makes the performance upgrades.....cuz either imma go slotted rotors with a stock 280zx caliper or i wanna get a sweet performance caliper thats a strait bolt on....
evildky
06 Nissan 350Z GT
here ya go big spenderhttp://www.arizonazcar.com/510brakes.html
mipo510
oooooohhhhhhh.....for sem reason i knew some one was gonna put a willwood pics on here..haha..and there it is..... but in order to do this set up...the caliper braket to use that caliper is $$$....and that lil red thing up front is $$$ tooo......
oh man....i just need a strait caliper to put in......ayayai!!
evildky
06 Nissan 350Z GT
I don't think there is a bolt in upgrade caliper for the 280zx, the outlaw 2800 might fit it bolts to the s30 struts but is intended for a slightly larger diameter rotor than the S30's it's what I am running, might fit the s130 strut?here is the tech pagehttp://www.outlawdiscbrakes.com/2800.htmlhere is one place tht sells them for about $130 each which is cheap!http://www.jrmotorsports.com/p...8.cfm
mipo510
like Borat states..'i likes".....
well ok.....i just wanna know what do i need to het my car on the ground and running...its been a yr since its been driven...a lil accident took it out for a yr...and thats why im doin the upgrade cuz my front suspension got mest up gooood.....
if i use the wilwood caliper...i can only use wilwood brake discs right?.... and if so...imma need that red lil hat or adapter thats on the above pics to install the discs....??... and with that outlaw caliper i may or may not need the braket to install it right....
so whats the easiest set up...to get me goin..if ya dont mind me askin....i need sum help mang...
THANKS FOR ALL THE ADVICE...
evildky
06 Nissan 350Z GT
no willwood calipers bolt upoutlaw 2800 will bolt upbut you'll need a race rotor, outlaw or willwood doesn't mater it's just a generic race rotor, I don't recall the deminsions and you'll need a custom hat to bolt the race rotor to your hub
the easiest wayt to get driving is to keep the 280zx stock brakes which should have plenty of stopping power for a dime that weighs hundreds of lbs less than the s130
mipo510
Oh HEEk YEAH!!!
thats all iwanted to know..mista EVIL....i oh u plenty..alot of peeps b actin shadee,,,adn even down here in So CALI and crap....
ok so if i go the outlaw 2800 series caliper....how do i get those hats to instal the rotors....and will it fit all rotors or is there a certain rotor to get...
wilwood sell those hats??
Ithink this dude JKinnovations has them??
mipo510
oh yea i just saw all those brake numbers on the outlaw web page..OMG...which is the best or recommended caliper and disc??
evildky
06 Nissan 350Z GT
I'd like to reiterate that the outlaw caliper bolts to the s30 strut, and I think it'll bolt to the s130, all you gotta do is measure the distance between your mounting holes, should be 3.5 center to center
juan at jsk (havn't heard from him in quite a while) makes a kit for using the wilwood calipers, if he's still making them I believe he stopped quite a while back
terry (I seem to recll that being hie name) makes the outlaw kitshttp://www.outlawbrakes.com/brakes.htmland the kit I was speaking of uses the 12.19 x .81 vented rotor, you can get them by brembo, wilwood outlaw or any race brake manufacturer, he sells the hats for $250 a pair, but the 240, 280 and the 0280zx all use different thickness hubs so you'll want to specify what hud you plan on using to be sure that the hat is the right thickness
wilwood does sell hats and rotors that'll work but but might not be the right offset for the outlaw caliper, most people running wilwood hats and rotors are also running wilwood calipers, I seem to recall a total of about $1500 to buy all the parts form a seller that sells the pieces at a good price, the bad news is you have to measure and figure ti all otu and look through their catalogs to find the right part numbers for your application and hope you got it all right
mipo510
sweet.....but dam....alot of $$$$...haha....i saw that the rotor hat for the 280zx is like $350..omg.....oh..man....****....gonna take me a long time....and workin part-time aint gonna help...lol...
but i still wonder if that caliper would run good...on the stock 280zx rotors....
evildky
06 Nissan 350Z GT
why are you so bent on changing the calipers? whats wrong with the stock s130 set up? also be weary the s130 hub is thinner than the s30 hubs placing the caliper and toror closer to the wheel, you might be giving yourself wheel fitment issues, and the outlaw setup will not clean anything smaller than a 15" and the wilwoods need I believe a 16"
mipo510
s30?..s130??...r those other datsun cars??....lol...well i mean a stock caliper for a 83' 280zx is like $100 per side....and well aperformance uprade is like $30 buks a way......so i was like..****...might as well ask around for a brake upgrade u know.....
evildky
06 Nissan 350Z GT
sorry,S30 = 1970-1978 240Z, 260Z and 280ZS130 = 79-83 280ZXZ31 = 84-89 300ZXZ32 = 90-96 300ZXZ33 = 2003- present 350Z
mipo510
COOL..THANKS.....S130= 280ZX...GOTCHAwell i mean a stock caliper for a 83' 280zx is like $100 per side....and well aperformance uprade is like $30 buks a way......so i was like..****...might as well ask around for a brake upgrade u know.....
Return to “Datsun 510 / Bluebird”
