evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jan 13, 2009 10:38 am
#1, soulds like your engine rings are compresses, this happens after a couple hundred thousand miles, sooner if the oil doesn't get changed regularly, later if the oil is maintained, basically therings compress and won't seal tightly enough to build pressure at low engine speeds, when you speed the engine up you speed the fuel pump up and are able to build pressure
2, I'm guessing your To bearing is riding against the tines of the pressure plate, might want to try backing thoff the clevis ont he clutch pedal a bit and see if ti improves
3 these shifters sucked form the factory, assuming of course that your car is an n/a, you can replace the shifter bushings with chrystler door pin bushings, it's pretty simple
