evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jan 30, 2007 8:15 pm
if you have a 280Z it either came with an N42 or an N47, they shard combustion chambers but the N47 has more restrictive sleaved exhaust runners, the N42 which was on the 75-76 280Z is the more desirable of the 2, the n47 camn on the 77-78 models, as for the trans, any 70-83 240Z, 260Z 280Z or 280ZX transmission will bolt to your engine, if you felt really fricky the 240SX 5 sopeed will fit if you swap the front case with one form a Z and change the main bearing and over bore the cuntershaft holes, and as ice pointed out the 82-83turbo T-5 used a different output yoke, you'e bneed a custom shaft and mount
