The run down:
1976 280z
Its silver on blue and black interior.
I got the toyota 4x4 calipers with the 84 z31 rotors.
Worst thing is it sat for 10 years, all im planning on doing is:
1) Clean the HELL out of it. (did that)
2) Replace ALL the hoses on everything. (replaced a few most seem to be amazing, inside and out. I have some on the side just in case, they are easy to get too. The ones that arent I will replace.)
3) Drain EVERY FLUID on the car. The motor oil is 10 years old and BLACKER THAN BLACK. There was some brake fluid in the MC but not much and it was shot. (drained and replaced the Clutch master and slave cylinder. Soon replacing the Master cylinder with the 15/16 280zx one.)
4) After draining all the fluid, add the 4 piston toyota calipers and the z31 na rotors to the front, and find a rear disk set up. (im thinking the maxima set up, any advise would be cool. Im thinking about doing it AFTER I get the z running. The fronts still need the spacers, adaptors and brake pads. The rears need the rear conversion kit and the 240sx calipers.)
5) after the brake set up bleed everything (I plan on doing it more than once to clean it out good), brakes and bench bleed the clutch. (Already bled the clutch and feels so much stronger)
6)Paint the roll cage black (I dont like the rusted look LOL) Its SCCA appproved soo its a wicked roll cage the welds are orgasmic haha! (Cut the knee bar because that was a pain literally. Thinking about painting it a midnight blue now, considering I cant powder coat it.)
7) Replace battery, seeing if the tail lights work well, and probably getting better headlights.
8) Get an exhasut since its running right from the exhaust manifold! (My exhaust manifold is said to be better than the headers they offer, but might get headers because they are new and lighter. Not looking to spend if I wont gain anything though.)
9) Tires for the panasports, and better lug nuts. 205/15 fronts, 225/15 rears
10) MSA front bumper with the 240z turn signals, MSA carbon fiber spoiler, and ZG flares.
11) MAYBE a radio, the car has almost no luxuries, so not sure if I want to even put in a better radio or anything. (zune works well for me, and it has a cassette player)
12) Fix the window, it some how feel off track. (Fixed, but I need key for the locks of the car.)
13) DRIVE THE PHUCK OUT OF IT! (most likely will be in the spring)
What the guy said:
76 280z California rust free car(Coupe) it has full coil over suspension and 4 wheel camber plates to adjust the suspension. (IT IS SLAMMED TO THE FING FLOOR)
v
It sits lower than a 240Z and should handle like a slot car .
Toyota 4 piston calipers and rotors for the front brake upgrade and 15 inch Pannasports.
Its silver with black interior and has a full roll cage and comes with Vintage SCCA log books if you ever wanted to go racing its vintage eligible. (Tried researching for "Becks ultra high performance or anything like that but came up empty. I would love to speak with the owner.)
It Was an ITS car (improved Touring ) so it still has all of its street equipment and was never cut up or gutted or wrecked just the carpet was removed, has about 3 little dents but nothing major.
The full dash wipers lights door panels everything is all there.
2 brand new racing seats
It still has its original L28 motor that was rebuilt to stock specs and still has its original fuel injection & 4sp manual transmission .
Pics when I first go it:
Now some progress that has been done:
Took the disgusting bumper shock absorbers off. Did a bit of cleaning and dropped the intake+exhaust manifold, gas tank, and transmission. Looking to pull the motor to make life easier.
Still havent ordered anything, but this is how she sits right now:
^ Got some cleaning to do.
^Looks can be deceiving! This little bugger weighs alot more than I thought! I would say upwards of 25lbs.
^ SO light, its very nice and well built.
^Brought another 76 gas tank, which are RARE, but turns out it had a pin hole leak. Decided what the hell, and will restore my tank instead since it it nicer.
^ I think the "withdrawl lever", the metal spring type thing might be bent out of shape.
^ Clutch looks to be in place lol.
^ The only rust spots on the z. One of which is from scrapping the pavement, the other is a common area. In which the drain gets clogged, both are easy to fix and not serious.
^ Took out the stupid knee bar, looks much better. The roll cage is SO tight ti the body, that the driver side rood liner is melted from the rubbing friction against the cage.
Thats all for now! Thanks
