evildky »
https://forums.nicoclub.com/evildky-u13100.html
Fri Jun 15, 2007 6:23 am
all the L6 engines are interchangable any 70-83 motor and or transmission will bolt into any 70-83 model 240z, 260z, 280z or 280zx
as for swapping the 2.8 into the 240z chassis, it's up to you as to if you want to run carbs or injection, some of the 280 cylinder heads lack the mounting holes for the carb intake manifold, I believe the P79 is the only one lacking these holes but I wouldn't bet on it (look on the passanger side between the spark plugs for #1 and #2 at the base of the head and you'll see the cast ID: E31, E88, N42, N47, P79 or P90)
if you choose to run injection you'll have to drill a hole (about 1.5" IIRC) under the clutch master cylinder to route the harness through and then it's only a hadnful of connections to be made
differences in the 280z and 280zx it's just a matter of which blocks, pistons and cylinder head they have, a popular combo si the flat top F54 block (this casting is on the drivers side of the engine kinda below and beside the engine mount for a 2.8 it's either N42 or F54) from an 82-83 280ZX N/A with an N42 cylinder head from a 75-76 280Z, this combo yields a higher compression ratio with good size valves, the 2.4 heads had smaller combustion chambers but smaller valves as well
the RB's are an option but way overpriced IMHO, the rb20 is cheap enough but at a major loss of displacement, the L28ET is what I have and what I recomend, it's 180 hp stock and really easy to make lots more power form, I'm at nearly 300 to the wheel! in a car that origionally had aobut 120 whp!
