280z misfire Need help
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Huggies1978
Car: !978 Datsun 280z
I have a 78 280z that likes to misfire when it gets to runing temperature i have tried timing i have tried a new coolant temperature conector but not the sensor if anyone has any ideas please let me know
NSR_s30
Car: '99 Ford F250 7.3L Diesel
'71 Datsun 240Z
Check plug wires, spark plugs, injectors?
ravera
Car: 1971 Datsun 240Z
Once you've figured out all the plugs and injectors are firing, take the plugs out, if they're really carbon coated, check the thermaltime and the cold start injector... The computer may be leaving the cold start injector on after it's warmed up leaving WAY too much gas in the motor.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
O2 sensor? a bad O2 sensor will cause the car to run a bit rich
have you checked your ignition tiing? have you tried adjusting your afm?
Return to “Datsun Z Forum”
