280z lsd
General discussion forum about all things Datsun! NOTE: If your thread is specific to a certain model, please make sure you post it in the proper forum.
Bwana
Car: Denali
I just purchased a IRS setup for the MG that uses a 280z pumpkin and I'm looking for either a lsd carrier or a complete pumpkin. Recommendations?
Thanks!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
good luck, the ideal donr is the 87.5-89 300ZX turbo's, they came with a 3.7 clutch type LSD from the factory (easy to spot on the car due to their finned diff cover, I assume your 280z diff is the r288 found in the manual tran 76-78 280z's, many name brand manufacturers sell R200 diffs in helical or clutch type but they use the larger 12mm ring gear bolts manyr people feel you need to use spacers and just as many feel the ring gear seats tightly enough on the cariers that it's a non issue, the 84- present units all used the 12mm ring gear retaining bolts
Boosted 70z
Car: 70 datsun 240z
Ditto, I have a z31 clutch-LSD in my S30 and am happy with it
evildky
06 Nissan 350Z GT
the 3.7 gears are a bit high for my liking, I'm thinking of swapping back to the 3.54's
Bwana
Car: Denali
My diff is a r200L, whatever that means...
evildky
06 Nissan 350Z GT
200mm ring gear
Return to “Datsun Chat”
