evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Oct 18, 2011 8:04 pm
rust rust rust, in thery being a texas car rust won't be an issue but when buying an s30 rust is the number one issue, check the rame rails under the hool for signs of creasing, they should be smoothe fomr the core support to the firewall, any waves or diples indicate it's been hit, also look at the firewall for any creases or wrinkles, again sign of an impact
mechanically, the L6 will last forever, the fuel injection can have age related issues, fuel pumps die, fuel injectors die, injector clips harden and crack, rubber air inlet hoses crack and leak air, not really a big deal but a carb swap is always an option
the trans assuminging it's a 4 speed will last forever unless you put a bunch of power to it, but not having overdrive gets old, if it is a 5 speed the 5th gear fork is prone to beaking, the zx 5 speed is a simple conversion and stronger
the stock wiper motor sucks, the stock headlight wiring sucks, these cars were wired backwards form what we do today, the result is voltage drop and dim lights
all things considered these are fairly simple and easy to work on and most parts are available, but for a DD, I'd drive the z32 and preserve the s30, the s30 has bottomed out on value and it on it's way up, the z32 is continuing to depreciate, although the z32 is much more difficult and expensive to maintainand repair, but also a lot more confortable to sit in traffic and with beter a/c
