280z alternator DIY?
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
Mattbarnes
Car: 1976 datsun 280z
If anyone has a DIY for the alternator replacement on a 280z, mines a 76, or a link to one,'could you please share it? Thank you!
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'm a little confused as to what it is that you are asking. Stock replacements are available at just about any parts store, online supplier or specialty supplier. If you're wanting to convert to an internally regulated alternator there were a couple of specialty suppliers selling plug and play solutions. Or you can runt he 280ZX alternator and add some resistors to the voltage regulator socket or there was a plug and play adapter sold through one of the specialty suppliers. http://datsunpartsllc.com/cart/index.ph ... 6&parent=7
Mattbarnes
I know where to get an alternator, my question was if anyone had a step by step guide on how to do it. Doesn't seem too tricky, but i don't want to mess anything up. Thanks for your advice though.
evildky
06 Nissan 350Z GT
It depends on which alternator you are using, there is the plug and play unit that requires nothing more than unplugging the voltage regulator. Or if you do the S130 or GM. Here si a write up on using the S130 alternator in a 280Z http://atlanticz.ca/zclub/techtips/alte ... index.html
Mattbarnes
All I'm doing is the stock alternator for the time being. That's my problem I can't find any DIY's for that. Can't be too hard I just want to do everything right
evildky
06 Nissan 350Z GT
You are looking for a write up on replacing the stock alternator with a stock replacement?
Disconnect the battery, disconnect the alternator, unbolt the alternator. Installation is reverse of removal, be sure to tension the belt, done.
ZMan69
Car: 1978 280z 1979 280zx
I just bolted up a 01-0039 gm alternator making it a one wire (f to +bat) and it literally bolted directly into the car (pulley depth and stock bracketry) mine is a 79, but I don't assume it will be any different.
-Nick
Return to “Datsun Z Forum”
