280 to 240 rear diff swap
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
bahrtman
Car: 1973 240z
2003 350z track
2012 titan sl
Anybody know if a 280z rear diff will work on a 240z?
Same stuff.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
The 75-78 manual trans equipped 280Z came wiht an R200, whereas the automatic versions came wiht the R180 found int he 240Z. Yes you can use the R200 but you'll have to change the "mustache bar" as well as the driveshaft for the 280Z which might need customizing, memory is a bit fuzzy on this one but there are a couple of input flanges for the R200 and I don't think either works with the 240's R180 shaft (if memory serves). Any decent driveshaft shop can make what you need or you take the trans, shaft and all form the 280 (also the clutch and flywheel you don't need them but larger area and holds more power)
bahrtman
Car: 1973 240z
2003 350z track
2012 titan sl
Thanks for your input. Finally got the swap done. Just one major screw up, I didn't flip the mustache bar around and had to pull it all apart to turn it around.
In my case, the 240z driveshaft did fit ok.
Return to “Datsun Z Forum”
