PSI240SX »
https://forums.nicoclub.com/psi240sx-u122.html
Sun Sep 14, 2003 4:39 pm
Spent a long day in Tampa with Scott and Mattback and the rest of the guys at Secret Services working on my coupe. Baseline was 226rwhp at roughly 9.5psi thanks to my greddy vaccuum T ghetto boost controller. My baseline setup was:S13 SR20DET, Greddy FMIC, 3" DP, Testpipe, and exhaust, Tubular equal lenght manifold, T25 with slightly larger compressor wheel.We started by installing HKS 264 step 1 cams and re-dynoing. That run was 235rwhp. Scott said that the stock ecu is not really mapped correctly for those cams. Next step was installing Tomei 740cc injectors and a Z32 MAFS, then retuning the ECU. We lowered the boost to stock 7psi and made 231rwhp. Installed an Apex AVCR to adjust the boost level correctly and turned it to 1 bar to achieve the 275rwhp. The boost bleeds off to about 11psi due to the tiny turbine but the car woke up considerably. Yesterday I discovered the speed cut at 117mph on the way to Gainesville for a track/drift event, today after tuning ecu and removing the speed cut I can tell you that the HUD only reads to 125mph but the car was going way faster! Felt touchy at that speed, can't imagine going over 180 in Scott's red rocket. Anyways, I like it but am still upgrading to the GT25R. I will retune for that turbo hopefully next week and update. Thanks again Secret Services for the tuning, and Enjuku Racing for all of my parts!!!
