275 azenis will they fit?
icemanthrilla
Car: 1990 240sx fastback
hey guys searched all over the place, wanna know if 275's will fit in the rear of my s13 hatch.sportmax 269 with 18" x 8.5's front and 18" 9.5's in the rear. If they dont fit does anyone know what to do to make them fit? by the way im gonna run tein coilovers and get 275 azenis. THANKS IN ADVANCE!!!!!
onosqv
Car: '92 240sx Vert
They will fit, but the front will bubble like crazy...
*EDIT: o yea, and the fronts, you'll be rubbing the fender wells, harness, fenders, etc depending on how low you are, what kind of fenders you have, what offset the wheels are, what profile the tire is, etc, etc.
icemanthrilla
would a small spacer for the fronts fix that? im probably gonna run 245/35. and falken only makes 275/35 for the rears. stock fenders btw.
onosqv
Car: '92 240sx Vert
245's aren't a problem in the front.
I'm running 265's. I thought u were trying to run 275's in front.
275's in rear no problem w/ a roll or higher offset rim... you can look through the wheel/tire threads we have floating around, they show all sorts of setups. That... and measure your current rims/tires & do a lil math.
