275/35 20s too big for an 02 Q?
peter-sanchez
Car: 2002 Q45
I have a chance to buy a great set of tires and wheels from someone who used them on a G35. The fronts are 245/35 20 and the rears are 275/45 20. Does anyone know if they are too wide for my car??
BadQ45t
Car: '21 Nissan Leaf SL Plus (wife's car)
'05 Nissan X-Terra S 4x4
'97 Infiniti Q45t SOLD! Miss the old girl
'84 Nissan 300ZX (Original Owner)
'16 Mercedes Benz S550e V8 Power & 35 MPG
I would think the offset would matter in this case, you might need spacers or you might need to roll your fenders in the rears. I know a few Y33 folks had to roll their fenders in the rear for 275's to fit on 19" rims so you'd probably be in teh same boat.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
with the right offset you should be abel to get 275s in the back of the Q...
Falkdesigns
Car: 1998 Q45t ~ EXE
You can fit 275's in there, I have them in the back of my Y33, and have seen them on F50's, but I'm surprised at the sizes, they went from a 35 in front to a 45 in back, which added to the back tires being 275 vs. 245 fronts means the back tires are a good bit taller than the fronts. In general, you go DOWN in aspect ratio size on rear tires that are wider so that the overall diameter stays roughly the same. I would expect to see a 275/30-20 in that case, not a 275/45.
245/35-20 has OD of 26.8"275/45-20 has OD of 29.7"
That's nearly 3" taller in the rear!!! Are you sure those are the right sizes??
Now a 275/30-20 is almost spot on with a 245/35-20 in OD size, off by only .1".
marksport
Falkdesigns wrote:You can fit 275's in there, I have them in the back of my Y33, and have seen them on F50's, but I'm surprised at the sizes, they went from a 35 in front to a 45 in back, which added to the back tires being 275 vs. 245 fronts means the back tires are a good bit taller than the fronts. In general, you go DOWN in aspect ratio size on rear tires that are wider so that the overall diameter stays roughly the same. I would expect to see a 275/30-20 in that case, not a 275/45.
My thoughts exactly. I would think that you mistaken as the title says '275/35/20' and in the post it is '275/45/20'
Like Falk says, the 275/45/20 is way too tall for a Q45. It will fit but it may cause VDC and ABS problems since the rolling diameters is nearly 11% different. And all the sizes listed above are already taller than what the oem rolling diameter for the G35 is. They may work but it makes the speedo even more inaccurate.
peter-sanchez
Car: 2002 Q45
Thanks Jeff. If I need spacer, would the installer know that?
peter-sanchez
Car: 2002 Q45
Thanks a lot Falken, I made a mistake when I typed the sizes. The rears are 275/35 19s.
peter-sanchez
Car: 2002 Q45
Thank Mark, I did make a mistak, the rears are 275/35 20s
peter-sanchez
Car: 2002 Q45
Oops, soty Falken they are 275/35/20
BadQ45t
Yes, they can work with spacers, I just had them installed on my car and the mechanic was able to figure it out easy. Get the tire sizes, the offset of the rims and than the folks here will tell you if you need them, or at least make good guesses.
