skydragoness »
https://forums.nicoclub.com/skydragoness-u193.html
Sun May 02, 2004 6:37 pm
Hello. This is my dilemma as of present:To illustrate what i have equipped before i describe my issue:
z32 26mm calipers, axxis semi-metallic pads, stainless braided lines from HeavyThrottle, slotted rotors drilled for 4-lug.
The issue i'm having, which i *also* had with my stock brakes, is this vague feeling that a pad shifts or there is an audible click when i go to apply light pressure on the brake pedal, the shift is felt thru the pedal, if i brake harder it doesn't occur, and i've noticed it happens at low speed/light braking i.e. a 'rolling stop' or something. And it feels like it's coming from the driver's side. I've been told it could be an upside down clip? Or a pin issue?
Thanks very much for the insight!
