268rwhp @ 11psi
fabio420
Car: 1995 nissan 240sx se
So I got the car back yesterday from putting in a new engine. Took it to the dyno to tune with the new t3/t04e 57 trim. At 11psi I hit 268rwhp/271 torque. I'll put up the dyno sheet wed. night after I go to the race track and find out my 1/4 mile time. For now, just a huge grin on my face evrytime I'm in my car. Btw, the engine is bone-stock and I've been beating up on it already.
KATwo40
Car: 1993 240sx KA-T
Gratz!
nissanfanatic
Car: 1992 Nissan 240sx SE
Nice! Definately get a chart up soon!
zerepdivad
Car: '90 240sx . '02 Lexus IS300
what's your current setup?
95 kat
Car: 95 240sx
yeah for real what set-up are you running? Those are great numbers for psi and turbo and all. Let us know,please.
fabio420
The setup is:Walboro 255 fuel pumpZ32 MAF550 side feed injectorsalphawerks manifoldt3/to4e 57 trim .50/.60arSAFC II24x7x3 fmic (turbo xs)that's about it plus u know, BOV, tial type wastegate, own manufacture dp
P.S. The car is an automatic
240SicknessX
Car: 96 240 SE
he is forgetting that he has a automatic transmission also. :P so kinda take in some kind of additional whp power loss.
{threadjack]*btw for anyone who is wondering, my second and third gear bands are getting weak after 8 months and about 9,000 miles w\ an estimated daily 275 whp. I beat on the car so if you are more of a conservative driver i can see your automatic ka-t transmission lasting a bit longer(or if you are making less power). This was with 20+ runs down the 1\4 mile, 5 drift events and 2 of those were on a private track so i was driving very very hard all day long. I drove the hell out of the car when it was na also for 25,000 miles. If your are more conservative, i would say your transmission would last about 12,000 miles before it starts to develop even more delayed shifting.*{\end}
Modified by 240SicknessX at 12:47 AM 1/24/2006
Craving4Boost
Car: 91 240sx fastback
thats great to hear. just wondering, what were your compression tests on the new motor.
Jookmasta
pics of the chart and ur setup needed. congrats................its been a long time workin on this thing. whats ur timing set at? also whats ur gap set at? congrats again.
fabio420
timing is at 15 degrees. not sure about the gap. as for the compression it was 160 across (the motor had112k miles on it)
S13 240SX
Car: 93 Mazda Miata
ka24e or ka24de?
fabio420
s14 de
sunnys14
Car: S14
so you are running 15btdc @ 11psi? imma try 12psi at the same timing
4felix20
Car: Emerald Blue S14
i'm curious what rpm you see your full boost at.
and if you auto guys ever need a replacement auto transmission, i just dropped one out of my parts car. only 62K miles on it.
KATwo40
Are you sure you just didn't burn up the fluid in that trans that's "delaying" in the shifting (also known as "shift flare")? When I was the Svc. Mgr. at Mitsubishi we experienced shift flares in the large Montero quite early (like 30k miles) and it was ALWAYS cured by a good trans flush. In fact, the only one I can remember that wasn't cured was one with like 150k+ miles.
Just a thought.
GEO
Car: 95 240sx KA-T
wait wait, why 15 degrees timing? Isn't that WAY to much timing retard? What kind of gas are you running? Werid I am pulling 21 degrees timing at 10psi. PUMP 92 gas, oh yeh.. YES another automatic KA-T !
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
well i think hes running 15 degrees base timing. so that means his total timing is at 23 degrees. which is still alittle bit on the scary side for me running 11 psi.
but non the less, great numbers, esp for a engine that kinda has lower compression and less boost. but i'm assuming its the advanced timing thats getting you those power numbers.
GEO
Car: 95 240sx KA-T
oh ****, I read it wrong... knocked 5 off 20, my bad. Yes nice numbers.
WDRacing
With a cooler and a good fluid the transmission in the 240 should last forever with 300 lbs of torque give or take a few. The internals are almost identical to the Skyline GTS-t.
WD
240SicknessX
Car: 96 240 SE
i changed the transmission fluid at 95,000 miles, its at 107,000 now, about 9,000 miles at 10psi.
it still shifts fine \ same at part throttle. wot takes about 2 seconds on the first to second shift though.
im running about 22 degrees (total) at 10psi.
oops, no transmission cooler.
i have all my 5spd parts in the garage.
WDRacing
I ran a nice big transmission cooler in my Skyline, worked wonders. Hot fluid will wreak havoc on the transmission and torque converter.
KATwo40
Trans coolers make a WORLD of difference.
fabio420
I'm actually working on gathering all the info that I need to install a transmission cooler. btw, if anyone knows which one to go with, I'd appreciate it.
PITCH
Wow looks like there are a few blown AT's out there. Good news to know that the auto trans will hold up to 300WHP
WDRacing
Any transmission cooler that's longer the 12" in the Summit Racing catalog will work fine.
http://www.summitracing.com
fabio420
Thanks WD, I mean Master shake! lol
WDRacing
Check in the junk yards for a cooler out of an RX-7, they will work great.
GEO
Car: 95 240sx KA-T
I got a transmission cooler on mine... I think its a Hayden 404 transmission cooler.
