265/40 ZR18 = No chance on G50, correct..
1992Q45A
That's what is coming on these MSW wheels
Pilot Sports ZR rated, expensive yet useless
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
I just checked the sizes, and its only 1.3% larger diameter.....
Meaning your speedo will read a touch slow (1-2mph at highway speeds)... If they're good load ratings (95+) your all good!
1992Q45A
Interesting
elwesso
2007 BMW M Coupe
Just checked on tirerack, and all the sizes I could find were at LEAST 97, and up to 101.. These seem like heavy duty tires and Id have NO problem putting them on my Q....
Ryan - I don't think those are 265/40's, based on the pics. I'd double-check, from the sidewall height those appear to be 235/40's.
265/40 would NOT fit well (width-wise) on those rims, as I have 8" rims and 255/40 were damn snug.
BTW, 265/40 is 2% larger OD than OEM. OEM is 26.1".
HeavyDuty
Car: 1995 Infiniti Q45
95 Nissan 240SX S14
96 Nissan D21
06 Nissan 350Z Z33
elwesso wrote:Just checked on tirerack, and all the sizes I could find were at LEAST 97, and up to 101.. These seem like heavy duty tires and Id have NO problem putting them on my Q....
That's capital HD to you, Wes.
1992Q45A
hitman,
I thought the same thing to, but she says that's what they are
Here is all the info she provided
The tires on the rims are Michelin 265/40 ZR18. The rims are a 5 lug pattern. Is this the information you are looking for?
Numbers and notations on the rims are as follows:
OZMade in Italy8 1/2 Jx18 H2C=180ET20G05001362 051As-7 LP
Well, then something's screwy.
The tires in the pics are shorter than mine, unless there's some weird optical illusion going on.
8.5 width is GOOD, though! Nice find.
szh
Car: 2018 Tesla Model 3.
Hmmm ... 265/40 might be a bit wide on the 8.5" rims. Check tire-rack for recommended rim range.
Also, if the offset is truly 20mm (is that ET20 I see?) then these are going to have fitment problems, I think! Particularly given the tire and rim widths!
Let us know how it goes! I hope it works out!
Z
1992Q45A
Well I have no clue on things like this, so thanks for the input
With shipping the total came out to 670.. Given the quality of the wheels and even the tires, I'm willing to give it a shot.
I'll order different size tires If I have to, I hope the wheels work out
