JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Wed Oct 11, 2006 11:48 am
Those calico coated bearings look good to me. But either are better than OE, so you really cant go wrong. For the $35 difference in price, i'd go with the calico coated ones.
Post up links to the camshafts you are looking at. SOHC or DOHC? You avatar is a SOHC but your sig is a DOHC.
Generally the longer the duration, the more valve overlap you will have, and the engine will 'lope' more. Be careful with long duration cams because too much overlap and there wont be enough vacuum to keep it running at idle (this is where high compression comes in).
