264 Cams Stock Valve Train Safe????
Sideways~S14
Car: 1995 Nissan 240sx W/ S13SR GT2871R
1989 Nissan 240sx Completely Stock DD
Im getting some brian crower 264 cams for my sr out of a trade from my friend im curious if this will be safe on a stock head i dont have rocker arm stoppers or anything all stock. an Im running 14lbs on a t28 with a stock ecu i know ill need a tune soon but just curious on how safe this will be.
S14toRPS13
I wondered this for a long time as well before I got my cams. I decided to go with the "Do it right or do it twice" rule. I know you're in a hurry to drop those bad boys in, but you know at the very least it'd give you piece of mind to upgrade the valve springs. With that being said, if you plan on revving up to 7000+ rpms, I'd just do the upgrade.
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
You can run those cams, but not recommended without Valve springs and retainers. Stock valve springs tend to bind under high rpms. If you are going to do any head work to a SR20, do it right the first time.
Sideways~S14
Lobo240sx wrote:You can run those cams, but not recommended without Valve springs and retainers. Stock valve springs tend to bind under high rpms. If you are going to do any head work to a SR20, do it right the first time.
Does this Binding occur with stock cams too? Cause it being my drift car its constantly tached out an near rev limit just curious if its only with aftermarket cams?
Lobo240sx
Sideways~S14 wrote:Does this Binding occur with stock cams too? Cause it being my drift car its constantly tached out an near rev limit just curious if its only with aftermarket cams?
It is possible but not likely. The binding usually occurs with aftermarket cams on stock valve springs. If you are constantly bouncing off the rev limiter I would get some rocker arm stoppers.
Sideways~S14
Ya Im hitting rev limit alot.... Ty For the Info!
