I brought a 1988 cefiro with a rb25det in it. little did i know the wiring in it was completely s***. Its currently running a 20de computer (not sure if its chipped) and loom with 25det injector loom. The problem is half the sensors on the engine aren't connected to the loom at all e.g my tps has two plugs but only one is connected.
So my questions are:
1. will a 20de loom mate up with all the sensors on a 25det (s1/2)?
2. can a 25det loom be connected to a 20de ecu?
3. Should i buy a 25det loom and ecu and go from there?
Any other info/wisdom would be much appreciated
