255 tire on an 8in. wheel?
240sxjeff
Car: nissan 240sx zenki version
Hey guys I was wondering if 255 would be too wide for an 8in wheel?Does any one have any pics? I am thinking it might bulge out too much but am not 100% sure.Any input would be helpful
McRussellPants
Car: 92 240SX
Tread Squirm city.
235/45 on an 8 is perfect square255/40 on a 9 is perfect square.
NoOneBetter
McRussellPants wrote:Tread Squirm city.
word
240sxjeff
hmm, I could have sworn 245 on 8 was a perfect squareWell I still have two more questions:What is Tread Squirm city?
And I'm thinking of going with a staggered setup, 7in F and 8in. R, does running 215 and 235 respectively sound right? Or would I be able to get away running 225 and 245 respectively without the bulge?
Once again thanks for the help guys
SmithSR
Car: 240sx
Don't overlook aspect ratio because only the full equation will lead you to the answers you need.
And even then, Different tire manufacturers use different yardsticks to measure their tires.225/45-17 from Yokohama to Falken to Toyo will have different casing and sidewall thickness, different tread depths, different overall diameters, different section widths.They will usually be close but we deal sometimes with such a minute margin for error that the answer will always be to mount one up and see what you think.
IMO, you should disregard 7" altogether.
You should make the goal to keep overall diameter as close to oem as possible. Any taller and you lose gearing, response.
8" 215/45-17 for the slightest of stretch. Not really even stretched.
9" 225/45-17 has stretch. 245/40-17 is ideal for fitment (very slight angle on stretch) and ideal overall diameter, but isn't available in a ton of brands.255/40-17 is getting to be too tall. diameters range from 25" to 25.20" both of which are above oem OD.But on the 9" with 255/40-17 you get a square shoulder. The trick is, this doen't fit for **** under the back of an s13 unless you start to roll fender.
The only problem with a perfectly square tire/wheel is it becomes harder to tuck and harder to clear the coilover spring perch. Sometimes to get a solid fitment, you need that sightest bit of stretch, like the 215/45-17 on 8" or 225/40 on 8.5" etc
240sxjeff
Well as much as I would like to diregard the 7" wheel I really can't find any other sizes in four lug. my Ideal setup would be 8in in the front and 9in in the rear but finding wheels like that in 4 lug is like finding a needle in a haystack for(without going over budget of course). Oh and this is going on an S14.Actually I found some 17x8 +35 & 17x9 +35 Work VS wheels (The wheels I was previously talking about were 16x7 +30 & 16x8 +30) but I think the offset is a bit too high for that wide of a wheel. Any input?
McRussellPants
Car: 92 240SX
Everything SRSmith said is ded on.
SPL sells 17x9 +20 FN01RC in 4H.
This is an S14? DAMN, just get 17x9 +20 all the way around and run 245/40 tires.
16s on an S14 look lame, there is no way to justify spending 1300$ on wheels and only go .5in wider than stock.
240sxjeff
There is no way on gods green earth that I am putting FNO1RC's.And I tend to like the way 16's look on S14's since I have 15in wheels on right now (because its a base model). This is the main reason why I am having trouble finding wheels They are just too hard to find in the right size and specs
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
yeah what's wrong with 16" wheels if you can find them in a decent width? IMO 16 fit an s13 or s14 perfectly, 17" start to look a little big, and 18+ is like woah.
240sxjeff
yeah you used to have 16's on your car before right? Do you have any pics of them that you can send me? I am sooo stuck in a bad situation here about which wheels to go with
Bronze MFP
i still have a set of the 16x7.5" kosei wheels. they're for sale. pics are in my cardomain page in my sig.i noticed a difference between the kosei and the new 17" mustang cobra wheels. The cobra wheels are slower, but it may be because there is a taller tire mounted to them. My car was definitly quicker on the kosei's
240sxjeff
Yeah I like the way 16's look without aero(but I have a Greddy front lip). If your wheels were 4 lug I would have bought them like 3 weeks ago, but unfortunately they are not I did not know you were going RB20 there is not much of the 2.0 out there, how much has it run you so far, if you don't mind telling me?
chandler
Car: 91 civic hb & 96 S14
how much for the kosei K1 wheels man? I live in charlotte also
Bronze MFP
chandler, email sent240sxjeff... whatever you pay for the engine itself, expect to pay that in replacement parts to get it ready (ex: clutch, timing belt, water pump, etc)
240sxjeff
yeah thats what I was figuring, I just had a hard time finding replacement parts for the rb20, which is what distracted me from that project
