On 9x18 wheels ET35, 255/40 will work.WantaG50 wrote:H I can purchase a set of 350z touring wheels with tires for 100! The tires on the wheels are 255/45/18. I would like to know if 255's would work on the front and do they have a picture of them on a g50? Thanks
There are many grades of RE 050A. The XL rated one is identified as "Pole Position." Ours on the FGY33 lasted quite long and were very strong, maybe even a little better than the PS2. Not as good as the PS3.BadQ45t wrote:Either way you go make sure you go with XL load rating or pay the price. I had a set of Bridgestone 050A's that were very good tires but not XL and ended up blowing out the sidewall on an expansion joint after only 12k on them.
