Ummm ... generic tire size calculators do not account for the actual rolling diameter (tires and sidewalls flex) and also the section width and profile, etc.
The actual section width and profile can be different from tire to tire and what may fit with one brand/model of tire may be difficult with another if it is a close contact situation!
Same exact tire size on different brands/models may have slightly different speed difference values depending on the sidewall flex, shape, etc.
So, it is always best to use turns per mile value (as reported on Tire Rack for example) to compare if you want more accurate info.
Or get a friendly tire place to do a test fit!
Z
