tommey wrote:I think those guys where idiots, the CA18 is an awesome little powerplant.
Not many other 1.8 liter engines could handle 500+ hk stock.
Whats the name of your boost controller?, is it one of those noname china units?
It's an old apexi item. Came with the car from japan. New one will have to wait until after xmas.
float_6969 wrote:I thought the cylinder 3 issues were related to the intake manifold design, primarily that it causes cylinder 3 to run lean from too much air.
I have trouble believing that the fuel rail design is causing JUST the 3rd cylinder injector to run lower pressure. I could see 3 AND 4, but not just 3.
Other than that, I think your build sounds great. I have the same cams and cam gears, but I haven't gotten to run them yet, what do you think of them?
I'm only going off the condition of the spark plugs.
The new rail has only been in for about a month, so will have to wait and see.
I have a 26 manifold and will be making a custom independent throttle setup. But that will be a while off getting fabricated.
I love these cams. It's a shame that HKS has stopped making them.
The motor feels great, even down low.
And no lag on gear changes. Still on a stock gearbox too.
I do want to build up another head with bucket and shim. To get more lift.
I don't know how far I will go with that though. May change turbo setup by then.
