Reset the meter to 0-20 or 0-50ohms, your lowest range. Normal impedance of injectors is around 11ohms.
Convert to new style injectors, as replacing with more old style (1990-1994) are a waste of time an money.
For $600 drop in and ready to go,
this is the cheapest conversion to new style injectors. Bernie is the man and super reliable.
You won't find any quality injector upgrades for $500. Bottom end you're looking at about $950.
Timing should be set with the light when the car is warm. Timing should jump around when warming up, and then settle to 15.
