2500rpm jerk
phyco99
Car: 95 240SX Stock
Hey I need some help with my 95 240, when I drive and have the rpms at 2500, then it just jerks every so often. It happens when I drive and even when I rev the engine. Could it be the plugs, or cables? Any ideas? I check the drive shaft, but I know that it is not that because it is not a constant jerk, just once in a while. And it is not a timed thing. What I mean it does not happen every 10 secs, just random. Any help? Ideas?
Soravia
Car: 2003 Audi A4 1.8T
Check my post for Sputter issues.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
check the battery cables usually if its not connected to the batter ot connected well, you cant rev pass 2.5. i had that problem when i relocated my battery
dickie
Car: Killer Turtle
"limp mode" won't allow you to rev past that, so its possibly a MAFS/ECU problem?
some people have cured the hesitation around that rpm by replacing their grounds, its cheap so i suggest you start there.
phyco99
Car: 95 240SX Stock
I can rev past 2500, but it when I am cruzin at about 2500 rpms when it does this jerking. But all the ideas that I have gotten are good, so I am going to try them out. I will try to get new plugs and cables and maybe that can help. And also the grounding issue, do I replace both the one at the battery or do I replace the ground strap for the engine it self? or both? I am not a proffesional mechanic, but I like to work on my 240, so if it sounds like I am not understanding, then just bare with me.
dickie
Car: Killer Turtle
phyco99
Car: 95 240SX Stock
Great, I am on it and will try it this weekend, on both!!!
phyco99
Car: 95 240SX Stock
SHE RUNS GREAT NOW!! WHO WOULD OF THOUGHT THAT SOME NICE SIZE GROUND STRAPS CAN DO THE JOB!!! BUT I ALSO WENT AHEAD AND PUT IN SOME NEW NGK'S.
