numbnuts240 »
https://forums.nicoclub.com/numbnuts240-u42843.html
Tue Apr 06, 2010 3:19 am
it works both ways, the companies often don't see what their employees are doing on the job site, btw i'm referencing mainly construction since it's what i have the most experience with. osha will randomly troll sites and look for unsafe behavior. the guys on the scaffold may have been sent out with harnesses and and tie off equipment, and they are definitely trained on proper use, but that doesn't necessarily mean that they will use said equipment. if they're caught, the company takes the hit, not the employee, although that person will more than likely be terminated.
in this situation, tests should have been performed to determine whether the levels of methane were within the safe working threshold, and the proper precautions should have been taken (drilling vents). problem is, everyone is hurting monetarily, and they just want to get the job done, and done fast. i'm dealing with this every day, it may not be safety related, but it boils down to the same thing: get the job done, no matter what it takes, and try to save some money while you're at it.
