Shocker »
https://forums.nicoclub.com/shocker-u18595.html
Mon Jan 16, 2006 3:22 pm
Allright, I fixed my starter issue this afternoon, she turns over just fine now, but does not fire, i check all my spark plugs they all are sparking, i sprayed some starting fluid into the throttle body, and what do you know, she fires right up..but then dies after about 2 seconds, so that leads me to believe fuel is not entering the cylinders.. fuel pump does kick on and work, fuel lines ive traced about 10 times and they seem to be in the right spots, ive got the dampener line going to the top fuel feed, and the fuel filter going to the bottom. any ideas? injector problem maybe?
