240sxjeff wrote:If your on stock fenders I highly doubt your going to fit 255 in the front. With 255's it would probally stick out about an inch from the fender. Your best bet might be to run a 235 tire up front along with some negative camber, Then roll and(if you want) pull your fender a little bit. That way you should be able to fit that rim up front.
HAHAHAHAHAHHAHAHAH
Yeah right, 17x9+20 is perfect flush on stock S14 fenders. (Im talking about really conservitive flush too).
18x8.5 +25 will definately be under the fender and fit easily with a fender roll. However, while it would likely fit under the fender a 255 is pretty wide for an 8.5, Id use a 235 for an extremely slight stretch or 245 for perfect square.
